Heavy duty front coil springs?
ximy
Post by ximy »
Does anyone know where to obtain a heavy duty coil spring? Can another heavy duty or super heavy duty coil spring be fitted to our bumpside?
1967 f250 428
HIO Silver
Re: Heavy duty front coil springs?
Post by HIO Silver »
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
ximy
Post by ximy »
Thanks, they do have a heavy duty part number in stock. I may try those. I'm attempting to stiffen up the front of my 67 so it doesn't bob & weave so dramatically every time you make a turn or brake hard. Heavy duty shocks, steering damper, sway bar are all part of this ongoing process.
If anyone knows a of an even more stiffer spring please let me know.
1967 f250 428
guhfluh
Post by guhfluh »
I have a set of 73 F350 springs you can have if you're close. They'd probably be excessive once cut to length needed for a F250 though.
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
ximy
Post by ximy »
guhfluh wrote:I have a set of 73 F350 springs you can have if you're close. They'd probably be excessive once cut to length needed for a F250 though.
socal, I can get 350 springs around here... Interesting. I wonder if they are the same diameter. Thanks for the info.
1967 f250 428
guhfluh
Post by guhfluh »
I believe the coil is, but it's a thicker metal and taller...If that makes sense.
BobbyFord
Post by BobbyFord »
I have Moog Cargo Coil springs on my truck. I'm very pleased with them.
I recommend KYB Gas-a-Just shocks, also.
ximy
Post by ximy »
BobbyFord wrote:I have Moog Cargo Coil springs on my truck. I'm very pleased with them.
Thanks. I do think I'm going to go with a proper bolt on HD spring rather than mess with cutting and fitting 350 springs.
1967 f250 428
guhfluh
Post by guhfluh »
Try out the Bilstein shocks and a sway bar first and then make a decision on HD springs. Just the shocks made a huge difference on my F250 Crew, even though they're speced for a F100. I still have sway bars to add as well.
ximy
Post by ximy »
guhfluh wrote:Try out the Bilstein shocks and a sway bar first and then make a decision on HD springs. Just the shocks made a huge difference on my F250 Crew, even though they're speced for a F100. I still have sway bars to add as well.
I've used KYB's on my former trucks, with seemingly good results. When I looked for Bilstein, they redirected me to Belltech shocks.
Those Beltechs might be just the ticket... :)
Description
Belltech Street Performance Shocks
Belltech's Street Performance line of twin tube shock absorbers sets the standard in performance handling. Our engineers focused their attention on tuning the low speed compression characteristics of this shock absorber, which is responsible for controlling your truck.
1967 f250 428
HIO Silver
Description
Visit Shockwarehouse.com for Bilsteins, KYBs, etc. Good prices and their staff is really knowledgeable.
68 Mustang
65 Mustang
ximy
Post by ximy »
Reviews on the Beltech shocks are not good. I did find the Bilstein part number for the f100. They look totally bullet proof. I'm going to try those.
Internal Design: Monotube
Collapsed Length: 10.83 in / 275 mm
Extended Length: 15.89 in / 403.5 mm
Boot Included: Blue Straight
Mounting Kit: B4-KT1-Z097A00
Spring Seat: No
Finish: Yellow Paint
Supercedes: F4-B46-1105-H1
Part #: 24-184656
1967 f250 428
ximy
Post by ximy »
Shockwarehouse.com:
24-184656 F4-B46-1105-H1 Bilstein Ford E-Series Van Chassis
each $91.04
AJUSA.com:
On Sale!
each $80.46
46mm Monotube Shock Absorber
Sold Individually: Not in Pairs
To Buy Multiples: Change Qty in Cart
1967 f250 428
guhfluh
Post by guhfluh »
Don't buy the rears for a 70-72 if you have a 67-69, like I did... :x
I have two brand new useless rear Bilsteins now... :cry: :lol:
ximy
Post by ximy »
guhfluh wrote:Don't buy the rears for a 70-72 if you have a 67-69, like I did... :x
I'll use KYB's in the back. Thanks for the note. I did order the fronts. :D
1967 f250 428
