high boy springs
- Manny
high boy springs
all right fellas i have a question for you guys. How high does the factory high boy sit in the front. And if known what arch do the springs have, and can you get stock replacements. I have been researching out on the internet haven't found anything yet. The thing i want to know is how bad mine have sagged been pondering goin up 2 inches but if i have 2 inches of sag in the springs would hate to wind up with 4 inches of lift with 2 inch springs. So any information would be greatly appreciated fellas i thank you
Just another Ford fool named Dan.
The Junk that hangs around
67' F-250 highboy Camper special cross breed currently under way
http://www.fordification.com/forum/view ... 22&t=86706
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
woods wrote: The rust holes in my truck were a factory install (very rare).
- ChevyToughRebel
Re: high boy springs
Im kinda in the same boat. I have a 72 highboy and was wanting to know if there are any specs on the factory springs out there so I can see if mine have sagged too. I dont wanna have to buy new springs if I don't need to.
If only I could change my username ;(
- SteveC
try here not sure but scroll down to f250 style side and look under f250 4x4 and you should see how and where to measure http://www.fordification.com/dimensions.htm course this only really applies to high boys that haven't been lifted
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- ChevyToughRebel
That would work but I have my truck tore down to the frame and the springs on the ground. Just wondering if there are specs out there to measure the bare springs.
~ Shane
~ Shane
- heep70
Call a spring shop and ask for 1973 F250 4x4 spring info. They are only different by one leaf added to the front packs.
Greg
1971 F250 "Highboy". SOLD to "Highboy_Firefighter_71"
2000 Subaru Outback limited.
2000 F250 4X4 PSD SuperDuty Crew.
2010 Polaris 800RMK Dragon 155"
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig".
My last 1971 "Highboy" pics
- averagef250
There are two options for highboy springs from the factory, they both sat the same height though. The light GVW trucks (90% of them) had 5 leaf packs and the 7700 GVW trucks have 6 leaf front packs. The spring options and GVW choices are pretty much identicle from 66-77.5. 67 did not have the 7700 GVW option as far as I know.
- 71PA_Highboy
Your other option is to go with late model SuperDuty springs. You will have a shorter wheelbase, but the ride is better.
I sourced my springs thru Cage Offroad. The guy there has a 74 Crew 4x4 he is doing, so he understands the issues we face.
Ask for Jim - but he may be out hunting this week.
Good luck!
Eric
Good luck!
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 F250 4x4 (71) - OB - 360, NP435, D24, HPD60 4.10, D60,
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Here in new york there is a spring place thats 40 years in business and they say if the truck sits even and the springs are not inverted they are probably good.So I sandblasted mine and painted them. I also was told the new steel is'nt as good as even 30 year old steel
call deaver spring in santa ana california , or national spring in san diego [santee]. both of these places can set you straight,.
- Wes
I don't have the spec atm, but alignment specs will give a ride height measurement, and usually where to take the measurement. If I have a service manual, or someone else, with the spec I'll post it for future reference. The measurement will at least let you know if your springs are sagged, and give you a starting point for figuring lift.
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- 68f250guy
chevy tough rebel====1972 if you have 5 leafs c7tz 5310 j if you have 6 leafs c7tz 5310 v
look in npd for arch info
they say for 72 with 5 leaf 5 3/8" center of eye to top of spring where center bolt is
they do not list a height for 6 leaf
they have listed that all short ends (26 inches) and long ends(27 1/2 inches) are the same and spring width at 3 inches for the 67 to 79 f250
they do have listed a 74 to 76 6 leaf at 3 5/8 inches
- 68f250guy
wow i guess i should have read the original post date........
