bumps with lowered altitude!! (lots of great custom bumps!!)
- customcrewcab
re: bumps with lowerd altitude!! (pics please)
yea i know how goes with rims. i just don't like alot of the big ones out there.i would rather run steelies and hubcaps then alot of them. i like my hilbrands but theres acouple othere sets i would much rather have. since the crew is going to be my dd i holding out for some bad ass 20 by 15 rear and 18 by 8 front for the falcon.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
I have been watching Marz's thread, he is doing an AWESOME job. But this is MUCH different. May take some time. But it is on paper and the materials have been bought.
-Lance
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
- td
here's one i found a pic of, mabe to low to suite some but i would love to have this set-up on mine.
- td
Re: re: bumps with lowerd altitude!! (pics please)
20x15's will look absolutely killer on the back of that thing Customcrewcab. what style 20x15 are you talking about?customcrewcab wrote:yea i know how goes with rims. i just don't like alot of the big ones out there.i would rather run steelies and hubcaps then alot of them. i like my hilbrands but theres acouple othere sets i would much rather have. since the crew is going to be my dd i holding out for some bad ass 20 by 15 rear and 18 by 8 front for the falcon.
td, that blue one is bad a$$, even if it is to low. dont care for the grill being blue or two tone eather
- td
yea it is bad, i would imagine it has a front clip under it and a big step notch in the rear. this is the only photo of it i could find. i estimate the front clip at $1500 -2000 and a good 4-link $500-700 and then the bag set-up your probly talking about the better part of $4000 dollars for the whole set-up.
every bit of it,and you still got to buy the wheels/tires and lugs
thats more than i got in my whole truck
- customcrewcab
i would have look at what they are called. well there are two i like that weld makes. the backs are about a grand a piece right now. don't think i going 20 on the back on the crew unless the the rims and tries come down in price. i can buy tires for the falcon if its just a weekend driver. tires don't seem to last long here in the heat or maybe its my driven.
the falcon going get a frame, caged and tubbed. maybe airbag struts in the front. i am not sure plans mighht change. will be a few years until i can get to it.
- carcrafter22
Here is mine before I took the toolbox off and put the hood back on. I need to get the fender fixed, remove the fuel fill cap on the cab and get the new paint on it.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
nice ride
how did ya think to use all that stuff in a bump
- 1971ford
- td
a buddy of mine found another one and just had to post it. i love the grungy look with it all laid out like it is.
- la1031
Carcrafter do those dodge wheels bolt right up on a factory suspention??
TB...what is the offset and sizing on your wheels, I am thinking about a simular set up?
- td
la1031,la1031 wrote:Carcrafter do those dodge wheels bolt right up on a factory suspention??
American Racing Tourqe Thrust 2's
20x10's (4.5BS)
20X8's (4.25BS)
td, i didnt know you had 8s on the front
i guess i forgot or just over looked it
that makes me fill better about what i want to do to mine
